 Sleeping-plattforms - how to sleep inside
Surfy
PostSubject: Sleeping-plattforms - how to sleep inside   Mon May 26, 2014 6:57 pm
Overall there are more people out there, who use a tent, rooftent, trailer and so on. But some of us plan to sleep too inside of the car. This need a careful planning about, how to use the limited space.
Here i try to do an kind of compilation of sleeping plattform samples. Many links to websites and comunities who did their own collection of sleeping plattforms.
Here you will find many ideas, how others solve their plans to sleep inside with 1-3 Persons.
That is very helpful to find some inspiration if you plan on your own buildup.
Article in english:
http://english.4x4tripping.com/2014/01/sleeping-inside-of-car-overlanding-with.html
In german language:
http://www.4x4tripping.com/2013/12/schlafen-im-gelandewagen-innenausbau.html
I hope you enjoy Smile
Surfy
PostSubject: Re: Sleeping-plattforms - how to sleep inside   Tue May 27, 2014 7:22 am
That's excellent, more than one way to skin a cat ...  clapping
ridgeback
PostSubject: Re: Sleeping-plattforms - how to sleep inside   Thu May 29, 2014 6:27 am
Brilliant. Thanks for posting. I am planning on making my frame out of 40mm tuxbe (free from work). Quite lightweight compared with 75x75mm timber. The disadvantage is stuff can get lost underneath. Front panel to dashboard will be a slot in with middle panel being hinged. Passenger seat will recline flat and drivers seat as forward as possible. Gives 2.3m one side and 1.8m behind driver. 8ft roof rack up top. Cooker mounted on rear door. Led battery lights, think that's it!
PostSubject: Re: Sleeping-plattforms - how to sleep inside   Thu May 29, 2014 10:08 am
Have look at this material ridgeback - www.omnia-cs.co.uk/panelsc2.php
Scroll down to panels. I will have this built up as cupboards and units in my camper. Lightweight, strong, you couldn't ask for better.
I've no affiliation to this company whatsoever, it's just I believe this is the way to go.
PostSubject: Re: Sleeping-plattforms - how to sleep inside   Thu May 29, 2014 10:11 am
And ...
Although you wouldn't need this, for my RR I want to install this as flooring - www.omnia-cs.co.uk/flooringd1.php
Makes perfect sense!  cheers
PostSubject: Re: Sleeping-plattforms - how to sleep inside   Thu May 29, 2014 8:12 pm
Looks good stuff Tom,
Mr Frosty not good on insulation, quite a few mistakes made by who ever built it, seriously considering if we keep him long time to redo the inside.  clinking teacups
ridgeback
PostSubject: Re: Sleeping-plattforms - how to sleep inside   Fri May 30, 2014 3:23 am
Looks like good stuff but I already have my base. Chipboard! Not ideal but free! The design will allow it to be swapped if necessary.
PostSubject: Re: Sleeping-plattforms - how to sleep inside   Fri May 30, 2014 5:20 am
Hi Tom
It looks like good stuff------but I couldn't see the insulation figures of it, these would be very important to consider building a 'camper box' out of it-------the best at the moment seems to be sandwich rigid foam ??
Nigel
PostSubject: Re: Sleeping-plattforms - how to sleep inside   Fri May 30, 2014 12:59 pm
Can see what you're saying, but don't forget that I already have the fibreglass shell, so it wouldn't be for the skin of the camper (this I will probably insulate with basic loft-type wool insulation). What i was thinking of is the actual units. Made from a type of plastic, the honeycomb sheets can be heat-welded to create lightweight sink units, cupboards, beds, etc. Weight is the key factor when tackling sand, mud, etc. so although chipboard may be cheap, in the long term it can be false economy.
The only other thing I may use the Omina plastic for is the floor. There is a thicker version for this, so if the 1973 timber flooring is on its way out, this plastic may be the answer. We'll see, have to do a lot of homework first before deciding.
Surfy
PostSubject: Re: Sleeping-plattforms - how to sleep inside   Thu Oct 09, 2014 11:11 pm
Personally I use two 15l Engel Boxed, one as fridge, one as cooling box. Compared to other brands i safed a lot of height. From Waeco is a "Drawer-Style" cooling box (non fridge) availabel who allows you to safe much more height at sample - than in my build.
That gives enough space to sleep comfortable there. We life two months in this car on our transafrica.
There is no perfect solutions arround - just good compromises.
Surfy
PostSubject: Re: Sleeping-plattforms - how to sleep inside   Fri Oct 10, 2014 8:47 am
Can't have enough beer fridges Surfy! Wink
PostSubject: Re: Sleeping-plattforms - how to sleep inside   Fri Oct 10, 2014 7:35 pm
Thier speaks a man of experience, glug
» Sleeping-plattforms - how to sleep inside
» All in one sleep suits
» Rear storage / Sleeping platform
» my sleeping quarters
» Temps inside cold frame/hoop tunnel
