| | What are your overland drive(s) | |
| Author | Message |
Tom Mc Founder
Posts: 2371 Join date: 2010-12-09 Location: Bedworth, Warwickshire
onlyMark Cleaner
Posts: 60 Join date: 2011-01-19 Location: Cairo, Egypt.
 | Subject: Re: What are your overland drive(s) Wed Jan 19, 2011 8:09 am | |
| For various reasons (mainly it was cheap) I have a Mitsubishi Pajero/Shogun 2.8 diesel. It has a couple of extras like heavy duty suspension, dual batteries and a limited slip but lockable rear diff. The rest is standard. I've used it out in the desert quite a few times and it's pretty good as long as you realise its limitations of not so high ground clearance as say, a Landy and it doesn't do as good over high rocky stuff. But on sand it as good as most proper 4x4's.  |
Jas Moderator
Posts: 1269 Join date: 2010-12-29 Age: 24 Location: Wiltshire
 | Subject: Re: What are your overland drive(s) Wed Jan 19, 2011 12:25 pm | |
| | onlyMark wrote: | For various reasons (mainly it was cheap) I have a Mitsubishi Pajero/Shogun 2.8 diesel. It has a couple of extras like heavy duty suspension, dual batteries and a limited slip but lockable rear diff. The rest is standard. I've used it out in the desert quite a few times and it's pretty good as long as you realise its limitations of not so high ground clearance as say, a Landy and it doesn't do as good over high rocky stuff. But on sand it as good as most proper 4x4's.
Excelent: I love pajero/shoguns. Most pajero's in the uk are the 3.2 DiD engine. My truck is based on pajero model but with a different trans and engine. Look foreward to seeing some pics! _________________ Looking for a new Vehicle
onlyMark Cleaner
 | Subject: Re: What are your overland drive(s) Wed Jan 19, 2011 2:49 pm | |
| Mine is an export model I got direct from Japan and bought into Egypt and it was virtually the last of the 2.8's. It was at a cheaper price to get rid of the stock before the 3.2 came in. I've never driven the larger engined one so I've no idea what the differences would be. Mine is as basic as it comes and, for example, only has a two speaker radio - no cassette or CD player, just a radio. I'm lucky I've got electric windows. I've just had service at 100,000km and had it four years. It'll have to be sold though in June due to a change in circumstances.
I have some pictures but it's mainly the car and the desert, the car and the desert, the car and the desert - type of stuff. |
Jas Moderator
 | Subject: Re: What are your overland drive(s) Wed Jan 19, 2011 3:31 pm | |
| Will you replace it with another 4x4?
onlyMark Cleaner
 | Subject: Re: What are your overland drive(s) Wed Jan 19, 2011 5:44 pm | |
| I hope to. It might even be another of the same. Due to the work of my wife she is eligible when we move to a new country for a duty free car each time. The problem is not all cars can be supplied and there are only a certain amount of companies that are affiliated with her work. So it does depend on what they can supply at the time we want it. When I was after this one it was a toss up between this and a Nissan Patrol. This one worked out better and I'm very glad I got it. |
onlyMark Cleaner
Reddisco Gate Opener
Posts: 34 Join date: 2011-01-05 Location: N.I.
 | Subject: Re: What are your overland drive(s) Sat Jan 29, 2011 10:07 pm | |
| i've a 300 tdi discovery which i'm currently trying to sort for overlanding. |
Jas Moderator
 | Subject: Re: What are your overland drive(s) Sat Jan 29, 2011 10:32 pm | |
| Cool, look foreward to seeing pics.
What type of equipment you getting for the disco? Just a standard vehicle with sotrage of are you gunna fit all kinds of mods.
 | Subject: Re: What are your overland drive(s) Sat Jan 29, 2011 10:59 pm | |
| | Terracan Jas wrote: | Cool, look foreward to seeing pics.
TJ |
Plan is get it sorted mechanicallly full service, timing belt kit, water pump, new pipes maybe alloy header tank as standard plastic one are prone to cracking and causing engine till overheat, change all oils gearbox axles etc
When i'm happy with that i think i'll fit diff gaurds, sump steering gaurd with built in recovery points and a snorkel also a roof rack as i'm thinking on a roof tent.
I'm also toying with making a front and rear hd bumpers rock tree sliders a detachable tow bar tank protector also debateing weather or not till give a 2" lift or not either way i'm changeing the springs for new ones it came with a set of std length koni heavy track shocks so i'm not sure to fit these wit std height springs or go for lift? |
Jas Moderator
 | Subject: Re: What are your overland drive(s) Sat Jan 29, 2011 11:09 pm | |
| Sounds good. IMO i look to try to keep the vehicle as stadnard as possible, ive fitted mods to 4x4's in the past and had it fail, leaving me stuck or stranded. When this has happened ive not been far from home. Ive not yet done any serious overland stuff yet only touring. But im sure the Veterans on here will give you all the info. My current truck doesn't have many mods just the usual; h/d 50mm lift, tyres, snorkel, storage and lots of equipment. 'If it aint broke dont fix it' eh. Hope it all comes together good and drives fine. Keep us informed. TJ _________________ Looking for a new Vehicle
4x4overlander Just got AT's
Posts: 202 Join date: 2010-12-25
 | Subject: Re: What are your overland drive(s) Sat Jan 29, 2011 11:25 pm | |
| Red, if you are thinking of a roof tent you dont need a roof rack. Three roof bars wil cope.
Brendan |
 | Subject: Re: What are your overland drive(s) Sun Jan 30, 2011 11:53 am | |
| | 4x4overlander wrote: | Red, if you are thinking of a roof tent you dont need a roof rack. Three roof bars wil cope.
Brendan |
Yeah and that mite be done for a while to save money although I am paricaled to the look of a big rack on the disco like the safety devices rack but these are rare and expensive I have seen copies for sale so I mite get one of these or I'll custom make my own. Although I'm also thinking about an oz tent instead views on either would be welcome ps I would probably be looking a s/h roof tent. |
roamingman Terrain Adept
Posts: 782 Join date: 2010-12-25 Age: 65 Location: Nearly thier
 | Subject: Re: What are your overland drive(s) Sun Jan 30, 2011 1:11 pm | |
| hi we have oztent great bit of kit, wife didnot like the idea of going up and down a ladder in the night, we have a D3 with a R4 just fits inside, will not fit inside D1/2 so will need roof bars.  |
Mac Just Bought 4x4
Posts: 91 Join date: 2011-01-03 Location: South East Kent
 | Subject: Re: What are your overland drive(s) Sun Jan 30, 2011 1:45 pm | |
Tom Mc Founder
 | Subject: Re: What are your overland drive(s) Sun Jan 30, 2011 9:03 pm | |
| ... and check out those chairs, each one costs more than my entire tent! A simple double-skinned 3-man pop up, quick and easy, that's the way I like it. |
 | Subject: Re: What are your overland drive(s) Sun Jan 30, 2011 9:18 pm | |
| | Reddisco wrote: | | 4x4overlander wrote: | Red, if you are thinking of a roof tent you dont need a roof rack. Three roof bars wil cope.
Brendan |
S/H roof tents?? Good quality roof tents i.e. autohome/maggiolina range ones go on ebay for almost as much as new ones! Have seen people sell 2/3 year old Maggiolina tents sell for what they must of paid for them
Oz tents? Biggest cons for them are the packed size and the price. Again they hold their value very well. The Oz tents latest creation the Jet tent packs up to half the length of the standard Oz tent. Due to hit the UK shores shortly.
Just be careful of the el cheapo roof tents on ebay. Some are made from pvc canvas??? OK if you like sleeping in a plastic bag I suppose.
I am now a great fan of the Foxwing and that is not because I sell them!
Roof tents are ok if you are young with a strong bladder! Personally I don't like the idea of ladders when I fancy a pee at 3am. I prefer ground tents personally
Brendan |
Tom Mc Founder
 | Subject: Re: What are your overland drive(s) Sun Jan 30, 2011 9:57 pm | |
| My mate had a funnel and a long hose leading down to the deck. It was only because of excess alcohol partying at a 4x4 show that he needed a pee in the night at all. Worked for him, no harm at all. In fact, once upon a time I purchased a brand new 'pee tube' at a military show - no, seriously! Stupid me didn't know what it was, just though the moulded rubber funnel and 3ft hose would be handy for filling containers. Found out later from an ex-squaddie that it was designed for an armoured vehicle, the idea being that when under gas attack the crew could simply unscrew the brass O-ringed bung at the bottom of the funnel and "let the water flow". Glad it was new when I bought it as I had used it for drinking water before I found out!!! |
 | Subject: Re: What are your overland drive(s) Mon Jan 31, 2011 11:45 pm | |
| Was just goin of what I was told elsewhere about s/h roof tent was good few pound too be saved I've checked on and off but never seen one on eBay maggiolina anyways. I quite like the idea of a roof tent up of ground poss less sand inside? Seen the foxwing in mags looks good thought it was just a awning though? Big££? Do u think the oz tent would be good starter tent or other suggestions?
Hey roamingman how long does it take to put up and take down? |
chally2 Just got M&S Tyres
Posts: 141 Join date: 2011-02-01 Age: 32 Location: berkshire
 | Subject: Re: What are your overland drive(s) Fri Feb 11, 2011 2:25 pm | |
| Hello, i have a standard d2 with AT tyres. It copes well of road. How ever for overlanding what mods are best. I don't want to go mad. I'm definetly going to add steering guard, strong bumpers. I have a metal on the front but found out last weekend I can't use them for jacking up. i've got a roof rack and high lift jack.
do I need split charge system. diff guards rock sliders
It would be good to see the other discos storage solutions
Cheers for any advice[img][/img][url][/url] |
