 Corrosion problem
Anth_smith
PostSubject: Corrosion problem   Mon Oct 14, 2013 4:41 am
I have a pic but can't upload it off my phone it's a small patch on the rear bottom quarter panel. What is the best (cheapest) option to get rid of it?
Cheers anth
PostSubject: Re: Corrosion problem   Mon Oct 14, 2013 8:10 pm
Hi
What is the vehicle ??-----can we assume it's a Landy ??-----if so, don't worry too much about it--------but treat the whole vehicle to LOADS of waxoyl-------the chassis is what you need to really worry about Sad Sad (and the bulkhead)
Nigel & Pamala
EDIT-------I just saw your welcome post-----I see you have a 300 Disco----not quite the same as a Landy ----------check the wheel-arches from inside and very carefully check the seat-belt mounts for rear seats (second row--not rear dicky seats)-------in fact check all the 'body structure' before you start preparing it for off-road travelling--------these are VERY capable but do suffer from the tin-worm:( Sad
Nigel
BTW ----welcome to AO:clapping: clapping
PostSubject: Re: Corrosion problem   Tue Oct 15, 2013 1:23 am
Cheers anth
Whereabouts do you live?
Corrosion problem
» Major Flea Beatle Problem!
» Green Ice Lettuce problem
» any help on tomato and pepper problem
» Lettuce problem
» Seed Potatoes Problem
