 wheel bearings
iveco4x4
PostSubject: wheel bearings   Sat May 18, 2013 9:16 am
any hints on checking tightening or replacing wheel bearings (front) on an isuzu doublecab pickup (tfs 69)
Yep - Its MOT time
Rich
Ex Owner of Tiggurr The 101
PostSubject: Re: wheel bearings   Sat May 18, 2013 11:12 am
If it was for a Land Rover/Range Rover I'd suggest a big hammer, but as its a Jap motor I really have no idea. scratch
Time for my tablets already nurse?
PostSubject: Re: wheel bearings   Sat May 18, 2013 11:42 am
Rich
Strip off the freewheeling hub outer and pull it off the splines, remove the dished plate fitted to the nut and its gubbins, most are Torx but not all, if it is the split type nut with captivating stud then undo this tiny stud, if it is the washer plate type then knock the tab back; tighten the nut reasonably tight and spin the wheel slightly, undo it just a tad and spin the wheel again, and keep undoing until there's no play or binding of the bearing. You leave the wheel on to do it.
PostSubject: Re: wheel bearings   Mon May 20, 2013 12:48 pm
See you still need a hammer then. Very Happy
iveco4x4
PostSubject: Re: wheel bearings   Mon May 20, 2013 5:32 pm
Thanks Assasin, the bearing setup was not as per your description but you gave me confidence to go in and do it and I found a circlip that removed all the freewheeling hub interior then 3 screws to be undone to get to the 'nut' (ie. not nut shapped but it did the job)
So only to do brake pipes, lower steering joint , new exhaust box and adjust the lights.Just got to wait for the parts to arrive now from milners
No hammers required !
Rich
PostSubject: Re: wheel bearings   Tue May 21, 2013 3:53 am
Typical, yours is the other less popular type.
iveco4x4
PostSubject: Re: wheel bearings   Tue May 21, 2013 6:28 am
Story of my life getting nowhere fast
Rich
wheel bearings
» dismantling the end of the torsion axle on our dandy designer trailer
» Wheel bearings
» Lubricating Wheel Bearings
» What is four wheel drive
» Wanted spare wheel
