 Hyundai Terracan Clutch
johnbb_1964
PostSubject: Hyundai Terracan Clutch   Sun Apr 28, 2013 6:41 pm
Hi I have just purchased a UK 54 plate 2.9 Terracan. 104K with full history. 85% of the time you need to be quite firm to get the gear leaver to go into gear, the other 15% of the time it's fine. No clutch slip at all and I have just driven 250 miles home with it no problems. I believe it needs a clutch and I have just dropped it off at my mechanics for a look. I am looking for a bit of advice:
1) What is the view on replacing the flywheel - I know it's recommended but whats the impact of not doing it?
2) Is there a cheaper way to replace/repair the flywheel - they seem to be very expensive and i read somewhere that they cannot be skimmed
3) Does anybody know of a good place to source the parts at sensible money?
4) Anybody know of a good clutch place that could do the job, i fear my mechanic won't take it on!
5) If I keep driving the car as is - very useable, am i likely to do more damage.......if not i might just use it as is for the moment.
Thanks for your help John
PostSubject: Re: Hyundai Terracan Clutch   Mon Apr 29, 2013 12:47 am
Hi John, welcome to the forum. cheers
Doubtless the Terracancan Brigade will be along shortly to answer your questions.
PostSubject: Re: Hyundai Terracan Clutch   Mon Apr 29, 2013 1:24 pm
Depends if it has a DMF, if so then the best thing is to buy a solid flywheel kit complete with clutch, no more problems.
If it is a standard flywheel then take it off and have it skimmed by a reputable company as they can mount it correctly and measure any run out with a dial gauge and take the exact amount off to flatten it, and the same off the raised flange portion so it has an equal amount off across it; if its too far gone for skimming them they can tell you before skimming it, most people tell you they can't be skimmed so they sell you a nice new flywheel because its in their financial interests to do so.
johnbb_1964
PostSubject: Terracan Clutch   Wed May 01, 2013 2:12 am
Thank's for the feedback, The local Hyundai dealer quotes £625 for a clutch replacement and £1350 if the flywheel needs doing........and yep you don't know if the flywheel needs doing until you strip it down.........ouch!
PostSubject: Re: Hyundai Terracan Clutch   Wed May 01, 2013 4:43 am
If its DMF then replace it if you intend keeping the vehicle as DMF are more trouble than they're worth, you know its been done and a solid flywheel and clutch kit can be supplied and fitted by an independent garage for around £700, as its a Mercedes item and they are popular engines the solid flywheel and clutch kits are plentiful and readily available.
johnbb_1964
PostSubject: Terracan Clutch   Wed May 01, 2013 5:11 am
Thank you, I like the sound of that........do you know any places that have experience of doing it? I have talked to a few places and they will only quote for "what the book says".
cuza68
PostSubject: Re: Hyundai Terracan Clutch   Thu May 30, 2013 3:31 am
where abouts are you??? If you are looking for a job well done by someone who knows what they are doing have a word here.
http://tiburonauto.co.uk/contact-us/
Ross is a sound chap and knows his stuff and wont rip you off.
» Hyundai Terracan Clutch
» Terracan TLC
» Terracan Key Fob
» My Terracan mods
