 Towing capability mitsubishi
mugwump
PostSubject: Towing capability mitsubishi   Wed Nov 28, 2012 5:38 pm
Friend of mine is looking at purchasing either a 2001 Shogun 3.2 diesel or a 2004 L200 warrior and was wondering which had the better towing capability. clinking teacups
There are things known and there are things unknown, and in between are the doors.
http://www.facebook.com/ChooseACheese?ref=hl
PostSubject: Re: Towing capability mitsubishi   Fri Nov 30, 2012 5:38 am
01/ 3.2 diesel LWB has a towing weight of 3300Kg and the SWB is lower.
Warrior is around 2000Kg.
PostSubject: Re: Towing capability mitsubishi   Fri Nov 30, 2012 7:23 am
There is also the Isuzu Trooper at 3500kg.
PostSubject: Re: Towing capability mitsubishi   Sat Dec 01, 2012 5:00 am
You've obviously not towed with a Trooper with 3,500Kg on the back Tom, not recommended as it pushes the back end everywhere and is dangerous.
PostSubject: Re: Towing capability mitsubishi   Sat Dec 01, 2012 6:50 am
Ah! No I haven't. I bow to your superior knowledge. adore
Moral of the story - go by 'recommendation', not by the 'recommended' weight.
PostSubject: Re: Towing capability mitsubishi   Sat Dec 01, 2012 12:26 pm
I only had 2800Kg's on the back, this is the reason many were derated on later models.
mugwump
PostSubject: Re: Towing capability mitsubishi   Thu Dec 27, 2012 11:38 pm
Thanks for the info and the end of the day he got a Renault Van!!
scratching chin
» towing weights query
» Towing a Destiny
» OVERLAND Mitsubishi Space Gear +Xtras ->UK
» Mitsubishi Pajero J-Top
» Riva Destiny Towing Stability
